Wiseco Stock Replacement Piston?
Re: Wiseco Stock Replacement Piston?
why not run the Diamond pistons spec'ed to 20 psi of boost?
As far as rings...DO NOT RUN TOTAL SEAL RINGS https://ls1tech.com/ubb/ultimatebb.p...=012194#000001
We do have the 11503 piston which was designed to handle 20ps1 of boost. I have these on the shelf, your cost would be $570.00 with the pins. Rings will run you $199.00 and that is for a steel top ring. It will take the heat a lot better than the standard plasma moly ductile iron rings. I would stay away from the gapless rings.
Thanks,
Chris Gelineau
Diamond Pistons
877-552-2112 toll free
Thanks,
Chris Gelineau
Diamond Pistons
are those stock replacements??? anything should be done after installation??
Thanks,
Ahmad
Thanks,
Ahmad
you can get (Diamond Pistons) them for Stock Rod Length, or 6.125 rod if ur changing to fordged rods too... all u need to do is have a hone to 3.905 and ur gold...
that pretty much covers it
Im running them in my block. 3.905 Piston for a 6.125 Lunati Billet Rod
<small>[ April 14, 2003, 11:58 PM: Message edited by: T/A Medic ]</small>
I can also make them for you guy's in a stock bore size. It would cost about $30 extra bucks to do it and would take us about a week or so to get them done.
Thanks,
Chris
Thanks,
Chris
So assuming you want to build up the bottom end, what all is involved?
Pistons, Rods, any bolts?
also, I would imagine labor being quite a bit more on these parts than a cam or heads, is that true?
TIA
Alex
TIA
Alex
Jason - Our direct replacement pistons weigh ~ 405 grams. That is pretty darn close to stock if my memory serves me. If anything we should be lighter.
Thanks,
Chris
Thanks,
Chris
I can shift faster than you.
Thanks Chris. I have a stock piston w/ pin at the shop I can weigh. If you can tomorrow, post the piston weight and .945 pin weight for use with stock rods.
Jason
Jason
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DIAMOND:
<strong> I can also make them for you guy's in a stock bore size. It would cost about $30 extra bucks to do it and would take us about a week or so to get them done.
Thanks,
Chris </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Chris, how does these compare to stock in terms of weight? Would they be that much heavier/lighter to require rebalancing?
Jason
Thanks,
Jason
