PP LS6 stage II and G5X3
Anyone actually running this setup? I serched and all I got was you might have PV clearance issues but no real answers. Although I did stop at page 7. Dial is just way to damn slow for in depth searches. If you are using this setup and you had to do work what did you do?
You'll want to check that in the car for sure. The valves on the PP heads sit higher on the seats (atleast on mine they did) and I lost about .020" of clearance. Everyone said my F13 would clear no problem on a unmilled head with a 2.02" valve, but it was very tight and I had to retard it a couple degrees to get the intake side to clear properly.
