TSP's New 233/239 .603/.600 Camshaft ! ! !
Old 12-13-2004, 10:48 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Default TSP's New 233/239 .603/.600 Camshaft ! ! !
Texas Speed is proud to now offer the 233/239 .603/.600 112+2 LS1 Camshaft
Designed off our 231.237 camshaft, the 233/239 cam offers great performance for customers wanting big power with good p/v clearance!
The 233/239 camshaft features slightly more aggressive lobes than the 231.237 camshaft, but will still work with a single springs such as the 918!
Testing has shown 50+rwhp gains from stock camshafts, and a 18+rwhp gain over a 230/227 camshaft!
The 233/239 lobe design also helps to give the camshaft good piston to valve clearance. The camshafts lobes will also work well for customers wanting to run it with a bigger valve setup such as the PRC Stage 2.5 5.3L heads!!
The 233/239 .603"/.600" camshaft will be on special for $310 from now to Christmas!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 12-13-2004, 11:48 AM
94form2000z's Avatar
Looks sweet. Nice price as well.
Old 12-13-2004, 01:06 PM
black_z's Avatar
Where do you think this cam will peak on stock heads? 6400?
Old 12-13-2004, 01:39 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
How much gain over the good ol' 231/237?
Old 12-13-2004, 02:47 PM
SupahRich's Avatar
Wow, I like the looks of this cam. I'm definately getting a cam package from you guys before Christmas but there's so many to choose! Started out wanting the Torquer, then figured I would be happier with the 231/237 then started to read the MS3 fit stock heads as well and had my mind set on it.... NOW this cam looks pretty sweet Guess you guys will be getting a call from me with in the next week with a few questions.
When using the formula to determine the cam "lope" that I found in another thread in this forum... I come to a value of 16 v/s 13.5 with the MS3. Am I correct in using 110 for LSA since it's 112+2 or am I wrong? I know it sounds vain but I'm really wanting a cam that sounds plain evil at idle
Old 12-13-2004, 02:48 PM
DONAIMIAN's Avatar
RPM range?
Old 12-13-2004, 03:00 PM
LS1SS4ever's Avatar
Sounds great. Do i need to change the piston? 50 hp gain with the stock head?
Old 12-13-2004, 03:30 PM
!LS1 11 Second Club
why would you need to change the piston?
Stocker's fine.
Old 12-13-2004, 03:35 PM
pdd
pdd's Avatar
sounds like its gonna be a sweet cam.
Old 12-13-2004, 03:53 PM
LS1SS4ever's Avatar
Exclamation
Stocker's fine.
May be of high lift or the compression. I don't know how many hp can the stock piston can handles, but I hear that it's not strong
Old 12-13-2004, 03:59 PM
!LS1 11 Second Club
Stock bottom end is ok up to 500rwhp (or at least high 400's )
Old 12-13-2004, 04:01 PM
SupahRich's Avatar
The lift isn't as high as a few other cam's out there... such as the T-Rex or MS3... don't see why it wouldn't fit stock heads The compression ratio shouldn't change unless you use dish/domed pistons and/or different head gaskets or milled heads etc etc. Just swapping out cam's wouldn't effect it.
I think the stock pistons are plenty strong enough, too many people out there running a butt load of horsepower on stock shortblocks
Old 12-13-2004, 04:32 PM
nspr8td lt1's Avatar
18rwhp. no flycutting needed on stock heads. i dont remember if you said your 5.3's were milled. are they?
Old 12-13-2004, 04:37 PM
Zach@Texas-Speed's Avatar
I just put this cam in my car and its very driveable on the street and has a KILLER sound, my old cam was an MTI X1 (230/227) and I made over 18 more rwhp with stock heads, LS1 manifold and stock TB
Jason...its a badass cam, thanks
Zach
Old 12-13-2004, 04:38 PM
Tranzor's Avatar
They said they gained 18 rwhp over a 230/227 camshaft, not a 231/237.
I would expect with such a small difference in duration and lift between the 231/237 and 233/239 that the difference would be somewhere around 5-10 rwhp max...
Old 12-13-2004, 04:53 PM
Hardtop00SS's Avatar
What's the LSA on this cam?
Old 12-13-2004, 04:56 PM
Flawless02SS's Avatar
sounds like this may be the one for me. Is this cam a pavement pounder at idle, cause that is what I want. I want it to thump like the hot cam well a little harder than that.
Old 12-13-2004, 04:57 PM
Originally Posted by Tranzor_Z28
They said they gamed 18 rwhp over a 230/227 camshaft, not a 231/237.
whoops :banghead: thanks for the correction.
carlos, why dont you get a LG cam?
Old 12-13-2004, 05:04 PM
Tranzor's Avatar
This will thump WAY harder than a hot cam... the hot cam idle is lumpy, but not really that loud. My cam's idle is lumpy and VERY loud, so I imagine this one will be very similar.
Old 12-13-2004, 05:09 PM
LS1Tech Sponsor
Slowhawk's Avatar
I can verify there result's.A customer of mine ran the 231/237 Cam and switched to a 233/239 cam.He gained 20hp/10tq everywhere.The 233 actually idled alot better and drivability was better on his A4 car.
Quick Reply: TSP's New 233/239 .603/.600 Camshaft ! ! !
