camshaft position sensor, cylinder #2 misfire, throttle sensor bad...????
first off i have a '98 formula ws6
a4 w/64k miles on it, stock except SLF 85mm MAF and SLP LM exhaust.
ok so i took my car to autozone today to get it scanned as per Constrictor98T/A's advice. it popped a bunch of codes, 5 or so about my O2, then i got a throttle position sensor, a misfire in cylinder #2, camshaft position sensor "A" is out of range for current engine operating conditions, the voltage signal from camshaft position sensor "A" is too low for current engine operating conditions. i just replaced my plugs and wires, and #8 was misfiring for a day or two til i finally got it on there. it was fine for a few days, then it started idling like absolute ****.
so i've been stumped as to what could cause this. i've been getting really bad vibrations in my car lately, and its gotten much worse. the car surges/hesitates, and has difficulty starting the first time. it sometimes feels like its gonna die, and i can understand that now with the camshaft position sensor issue.
i guess my questions are for you guys, what could cause this and what can i do to fix it?
btw tomorrow i am getting a pr of new spark plugs to test out cylinder two to see if its fouling spark plugs or if i just got a bad plug the first time around.
any help or advice is welcome, i'm hurtin right now <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Re: camshaft position sensor, cylinder #2 misfire, throttle sensor bad...????
Have you checked the ground connections? Heavy braided wire hooked up to rear of drivers side head. And from the block to the frame.
<small>[ April 17, 2003, 09:50 PM: Message edited by: DaleMX ]</small>
where is the connection for the engine block? i don't remember seeing those two connections when i did my plugs/wires but then again i wasn't looking either. i'll have to check from below the motor as well later today when i get a chance, my buddy has my jack/stands at his house. oh well. thanks for the tip, i'll let ya know what i find out when i get the chance.
<small>[ April 18, 2003, 12:25 PM: Message edited by: cyphur_traq ]</small>
