tapping / ticking after broken spring
Old Apr 6, 2003 | 12:07 AM
BYBYC5's Avatar
*Bad Trader*
Default tapping / ticking after broken spring
,,,,i just replaced a broken spring today and now i have a tapping/ticking sound. wasnt there befor the spring broke/or while it broke and was running, the car idles smooth still and no apearnt loss of power but i know somthing is is wrong. its louder/deeper than the tapping of a loose rocker..its only there at idle and low rpm and goes away under load(above 1800 rpm). im stumped....maybe pushrod?bent valve?....i dont know what a bent PR or valve sound like ....... <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
<small>[ April 06, 2003, 12:09 AM: Message edited by: BYBYC5 ]</small>
Old Apr 6, 2003 | 12:17 AM
Hawk's Avatar
Default Re: tapping / ticking after broken spring
Bent pushrod I would check all the Pushrods but it is prolly the same one as the broken spring. A bent valves would backfire and loose power. BTW what kind of springs are you running did you replace all of them?
Old Apr 6, 2003 | 12:34 AM
dug's Avatar
dug
What spring did you replace and what cam are you runnin? I hope you didnt break a 918 spring.
Old Apr 6, 2003 | 12:50 AM
Fly By's Avatar
yea, bent valve. Happened to me twice now <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Say, didnt you have 941s on there?
Old Apr 6, 2003 | 11:06 AM
BYBYC5's Avatar
*Bad Trader*
ya 941s and thats what saved me(the inner dampner) ill check the push rod, wouldnt a bent valve cuz more problems than just a tickin/tapping sound? im not even hearing a miss
Old Apr 7, 2003 | 04:00 PM
BYBYC5's Avatar
*Bad Trader*
hmmm ttt havnt had a chance to taer it down yet
Old Apr 12, 2003 | 01:23 PM
BYBYC5's Avatar
*Bad Trader*
ok replaced the broken spring, and 2 bend PRs.
the bent PRs were on the opposit side of the motor from the broken spring. so, new spring and PRs AND STIL HAVE A FREAKING TAPPING!!!!!! im thinking bent valve but other than the sound i have no other symptoms of a bent valve. im stumpped!!!!!!!!!!!!! <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Old Apr 12, 2003 | 05:09 PM
99BackNBlackZ28's Avatar
collapsed lifter perhaps?
Old Apr 12, 2003 | 05:38 PM
BYBYC5's Avatar
*Bad Trader*
maybe, how can i check for a messed up lifter and which side its on, i cant really tell wich side the tapping is from.
Old Apr 13, 2003 | 08:49 AM
BYBYC5's Avatar
*Bad Trader*
ttt
Old Apr 14, 2003 | 08:19 AM
BYBYC5's Avatar
*Bad Trader*
ttt
Old Apr 19, 2003 | 12:04 AM
BYBYC5's Avatar
*Bad Trader*
ok replaced the bent PRs and # broken springs, noe the dam thing still tick/taps, slight loss in power but no other sympoms,
probability that it could be a ...
lifter.
bent valve.
anything eles. im stumped <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Old Apr 19, 2003 | 12:13 AM
danimal95's Avatar
chances are its a bent valve take off the rockers on the cylinder that had the broken spring and do a leak down test Ive seen the very same thing on several customer cars.Are you sure youi only had 1 broken spring?is it possible you over looked another one and thats where the sound is coming from do a leak down and that will show you your problem
