Need Help
Need Help
Hey guys I have a question.
Does anyone know if you can use a 6.0 litre crank in an LS1?
If so on a standard bore what cubes does that give you?
Any feedback is appreciated.
True. The 4.8-5.3 have the same bore size-just different stroke and rod length, and the 5.3-5.7-6.0 have the same stroke- just different bore diameter with same rod length. Like the old SBC 302-327-350, same bore diameter with different stroke sizes to make the different sizes of engine, 305-350 has same stroke different bore.
