97’ C5 back on the road after valve spring replacement
Old 12-31-2004, 10:59 AM
allthrottle&nobottle's Avatar
Default 97’ C5 back on the road after valve spring replacement
Some of you may remember my broken valve spring of late October:
https://ls1tech.com/forums/showthrea...08#post2009008
Finally got some free time and replaced them starting with #6 in the pictures below. Also did valve seals as I put on PP's spring seats.
Thanks to the good old LISLE valve spring compressor/cyl. Air pressure line they are done without issue!
Seems to run fine, after a heat cycle we took it out for a spin, runs stronger than ever.
A few things I noticed different between the Pioneer & PP Gold springs:
Pioneer spring uses 3/16” dia. outer wire and near 1/8" inner and both seat & retainer are a slight interference fit on the spring
PP Gold uses 5/32” dia. outer wire and right at 1/8" inner, is 3/16” taller and has a looser fit for both the seat and retainer
I like that loser fit better as I noticed some galling on the Pioneer spring seats & retainers.
Funny thing…….both double springs weigh exactly 3 Ό oz each!
Time will tell but all should be well.
Old 12-31-2004, 11:05 AM
2c5s's Avatar
I've that on both my C5's in the car. I'm glad I did not have to do it on a F body.
Old 12-31-2004, 11:16 AM
Shorty Director
VINCE's Avatar
Good job... How did you know your spring was broke? Many things cause a rough idle. Now if your idle is smooth as stock and then your car idles like a dragster I can understand, but that other post did not say that.
Old 12-31-2004, 12:58 PM
Well my other post said injector or spring......and I have been around broken stuff including springs before!
No codes were showing (you don't always get any codes.....) so that means mechanical breakage and the way it was driving on 7 cylinders it was my first educated SWAG.
Old 12-31-2004, 03:14 PM
Shorty Director
VINCE's Avatar
How did you figure out it was driving around on 7 cylinders?
Old 12-31-2004, 03:53 PM
2c5s's Avatar
It's easy, the car runs like ****, just like it's missing.
Old 12-31-2004, 05:03 PM
Shorty Director
VINCE's Avatar
Sounds like 99% of big cam'd cars or big cam'd strokers to me.
Old 12-31-2004, 05:21 PM
pdd
pdd's Avatar
lookin good
Old 01-01-2005, 11:01 AM
You will know when you get one on a stroker.......no power, idles poorly and it sounds flat....put your hands on the tailpipe and you can tell which side has the problem too!
