need help with passenger side valve cover
i'm swapping my factory valve covers on my 99 trans am. i did the drivers side earlier i was starting to do the passenger side when i saw that the passenger side valve cover on my car has a front and rear tube coming from it and that the one i'm was going to switch out for it has only the front tube. i know that the front tube is the pcv. what i need to know is what is the rear tube? should i delete it or put it into the other valve cover? if i was to need to put it into the other valve cover how would i do so?
Re: need help with passenger side valve cover
The rear facing tube was part of the pcv system, the front facing tube is the fresh air tube source for the crankcase.
