Got my heads flowed today
For those who don't know, I bought a used set of Absolute Speed Stage II 5.3's from a member on the board. (I am aware of the current situation with Absolute Speed, no comments needed). Allan @ FMS then took them and worked the bowls where he saw room for improvement to help the exhaust side. He also port matched the 90mm intake. Steven at TR (SAR2K) did my exhaust port/combustion chamber polishing, and did an excellent job.
Here are the numbers : (exhaust flowed with no pipe)
Intake --------- Exhaust------ Exhaust (pre allan)
.100 68-------- 59 -------------58
.200 135--------109-------------108
.300 196-------153-------------149
.400 244-------186-------------165
.500 277-------211-------------178
.600 299-------224-------------196
.650 293-------227-------------205
.700 290-------230-------------206
As you can see, Allan's porting did WONDERS on the exhaust. Special thanks to him and Candy for helping me get all this together, as well as Jason99T/A for flowing the heads and doing the install when we get a chance.
Pics of heads:
http://www.lsuxblake.cz28.com/photo4.html
Pic of intake port:
https://ls1tech.com/forums/showpost....3&postcount=14
Pics of heads:
Pic of intake port:
I can shift faster than you.
Yep, the intake flow #s are typos. He listed the .050" numbers. Here are the correct #s:
.100 68
.200 135
.300 196
.400 244
.500 277
.600 299
.700 293
Intake port was flowed with a radiused entry
No pipe on the exhaust
SF1020 flow bench
3.900" bore
.100 68
.200 135
.300 196
.400 244
.500 277
.600 299
.700 293
SF1020 flow bench
3.900" bore
.100 68
.200 135
.300 196
.400 244
.500 277
.600 299
.700 293
SF1020 flow bench
3.900" bore
.100 68
.200 135
.300 196
.400 244
.500 277
.600 299
.700 293
SF1020 flow bench
3.900" bore
SN95 Director
.100 68
.200 135
.300 196
.400 244
.500 277
.600 299
.700 293
SF1020 flow bench
3.900" bore
.100 68
.200 135
.300 196
.400 244
.500 277
.600 299
.700 293
SF1020 flow bench
3.900" bore
Originally Posted by jrp
did you CC' the chambers and measure the port valves as well. im just curious.
Originally Posted by Launch
From the pics these dont look like the latest CNC ones he did before going down. Anyone running or flowed his cnc heads?
OK cool. Reason I asked is I have one of his CNC 5.3 stg2 and it has the rough cnc finish on the chambers. Yours look a lot smoother. Im still waiting on the other head as its being sent seperately with some other parts before I can get em flowed.
Originally Posted by GrannySShifting
What did that cost, ballpark figure, to go over the exhaust port?
his advertised numbers Id have to bet prolly looked like this:
147/204/255/292/312 intake
114/161/200/220/228 exhaust
your numbesr on thunder bench are very similiar to ones weve found on a local bench with 2.05 absolutes Id like to know the before and after intake and exhaust port ccs... we didnt get a chance to cc his abs heads... and Id like to see how big the exhaust was when done, I dont mind big exhaust ports (done right)
