ticking from oil pan?
Old 01-21-2005, 03:16 PM
titleist's Avatar
Default ticking from oil pan?
i am getting a very loud ticking noise coming from what seems like the oil pan area. any ideas?
Old 01-21-2005, 05:26 PM
fasteddyss's Avatar
Not to be an alarmist but the only time I have heard that sound from the oil pan area it was a rod knock.
Are you sure it is not a exhaust leak??
Old 01-21-2005, 05:30 PM
Raise's Avatar
sounds like a bottom end problem...or something fell into your oil pan
Old 01-21-2005, 08:15 PM
TigerFan187's Avatar
My guess would be somehting bottom end. Ill pray for you that it isnt though! I just went through a simliar situation. 4 days after I got the LS1 in I started to get a bad knocking. Something(the TR-6 that went when I blew the old motor got caught in the heads or the guys doing my heads) got stuck on top of one of my pistons and scared 2 of them up and caused them to hit the heads. First thing you can do to check for the worst possible thing is the oild pan for metal shavings. Good Luck!
Quick Reply: ticking from oil pan?
