Piston to valve clearance with 60cc LS6 heads and crane 228/232?
Old 01-24-2005, 08:23 PM
95LT1Z28's Avatar
Default Piston to valve clearance with 60cc LS6 heads and crane 228/232?
My buddy just bought some LS6 heads that were milled down to get the combustion chambers down to 60cc. He is going with a Crane 228/232 112 lsa, .600/.600 lift and a gasket thickness of .051. Will he be fine on his piston to valve clearance with this setup? The block is still the stock deck height. Thanks!
Jeff
Old 01-24-2005, 08:27 PM
jrp
SN95 Director
jrp's Avatar
just measure it
Old 01-25-2005, 11:02 AM
madpwr1's Avatar
Originally Posted by jrp
just measure it
i'll bet any money he doesn't know how
Old 01-25-2005, 12:37 PM
goober35's Avatar
IF that cam clears it will be close. Although i have see some weird things lately.
Old 01-25-2005, 06:18 PM
95LT1Z28's Avatar
I do know how to measure piston to valve clearance on a LS1. This is my buddies car and I want to do the least amount of work possible on my half. Thanks for the opinions and advice though fellas! I will let you guys know how everything turns out this spring!
Jeff
Old 01-25-2005, 06:30 PM
LS1Tech Sponsor
Slowhawk's Avatar
Stock valve's will probly clear,2.02's will be very close.Like said before,just measure it out and be safe.
