Advertised duration for F13, F14 and TSP 233/239
Hey guys just wondering if you can tell me the advertised duration of these 3 cams. I'm torn between the three-losing sleep actually-it's pretty sad.
I have a F13 in the for sale section with all the specs listed. Here is the link
Originally Posted by jrp
so is it confirmed the TSP is cut on an XE-R lobe?
SN95 Director
Originally Posted by Beast96Z
It's not a comp lobe. It's a Lunati from what they told me. Brian sent me the specs and they were 49 degrees diffrent between advetised and .050. There could be some changes to the lobe pattern I guess, but the numbers look the same to me.
Originally Posted by 66deuce
that's only 10*bigger at .006 than my TR 220.i would've thought it would be more.
Wouldn't a faster acting lobe provide more low end vacuum which would in turn provide better driveability? It's seem like the F13 is very close to a XE lobe profile.
230-220=10* 280-270=10*. If both cams are on similar lobes, which they are, the numbers are in corelation. If you leave the same .050 duration and raise the .006 duration, you weaken the intensity of the lobe. For example, XE-R lobes have a seperation of 49 between advertised and .050", TR and Futrals are around 50, and XE's are 53, then some of the lunatis are 58 and 61. The higher the diffrence, the softer the lobe ramp.
