Need help Motor problems
I was at the local drag strip last sunday. And, I made one pass no problem but didnt run a very good time. Then ran again like 30 min. later and It ran good. I launch at 4800 it hooked then started spinning. At the end of the run it died so I cranked it back up and died again. I cranked it back up and kept it running by keeping my foot on the gas. The motor was making a Knocking noise and had 10 psi of oil pressure. I turned if off after I noticed that the car was making a knocking noise. The car is a 1998 Z28 6sp. has a tsp cam, ls6 intake and a ls6 oil pump. I put the cam, oil pump and intake on December 25. Need Ideas what is wrong.
