Loctite on heads install?
Old 02-09-2005, 11:36 PM
I8RICE's Avatar
Default Loctite on heads install?
I'm about to put my heads on and have arp head bolts. My question is should i use loctite? If so red or blue? Also, should i use anything when i'm installing my katech rod bolts on stock rods? TIA
~Rob
Old 02-09-2005, 11:50 PM
Cal
Cal's Avatar
I would say no for the head bolts. If properly torqued, you don't need loctite. It will just be that much harder on the threads next time you remove the heads.
Old 02-10-2005, 12:28 AM
jmX
jmX's Avatar
Supposed to put moly lube on the ARP headbolts before install so you get proper torque readings. I dont remember ARP saying any locktite was recommended. ARP actually lists 2 different torque settings depending on if you use moly lube or motor oil to lube the threads.
Old 02-10-2005, 12:45 AM
Cal
Cal's Avatar
If you have the ARP studs, not the bolts, they say you can locktite the studs into the block for a permanent installation. But I wouldn't do that either myself.
Quick Reply: Loctite on heads install?
