anyone running the TSP 231/237 come in
Old 02-13-2005, 09:24 AM
Nsty98LS1's Avatar
Default anyone running the TSP 231/237 come in
i think i've finally made up my mind on which cam i'm going to run. i've searched and searched some more on it and the 231/237 seems to be what i want. i bought a set of 3.73s for my car and with mods in my sig how is this thing going to run? i give up on trying to get similar dyno numbers because i see so much variation in peoples setup that it isn't funny. where will i my peak power and torque be(roughly)? how hard am i going turn the motor versus with stock? hows does it drive? this is my daily driver and thats about the only thing that kept me from doing the T-Rex. I am going to get a TSP mailorder tune, so should i get them to shut off my rear 02s? i also have my AIR and EGR because of the visual inspection but should the be shut off also or won't it matter if they still work? thanks in advance for the help
JASON
Old 02-13-2005, 09:32 AM
ta02zx10r's Avatar
Default 231/237
Hey man
I don't know if ya got my pm but I have a brand new one for sale I will let it go for 310 shipped. Let me know what you think. I have pics of it and the cam card as previously mentioned. thanks Chris
Old 02-13-2005, 09:42 AM
Nsty98LS1's Avatar
i got your pms and thanks the offer but TSP give me a good price on the whole package with oil pump, double roller chain, etc.
Old 02-13-2005, 10:05 AM
rons 00z's Avatar
i've seen full bolt on cars start around 380 and get up to 400 i reached 387 and with a lil more tunning i really think we can get it to 400 in a full bolt on cam car. if you dont have cats then have tsp turn your o2's off. as far as an estimate i think you'll pull around the same numbers as me 387hp 360tq
Old 02-13-2005, 10:08 AM
Tranzor's Avatar
The cam will peak around 6200-6300 rpms, so at the track I shift at 6700. I strongly suggest you get an LS6 intake, because this cam lives in the upper rpms... and that's where the LS1 intake because a choking point.
Old 02-13-2005, 10:26 AM
Nsty98LS1's Avatar
i plan on doing the ls6 intake in the near future but just not in the works right now. anyone else have any more info? like i first stated i've searched and searched and then search some more trying to find what i think is gonna be the cam i need.
Old 02-13-2005, 06:00 PM
Mike98WS6's Avatar
I have the 231/237. I love it. Make sure u have at least an LS6 intake otherwise you won't be happy with the results. As mentioned before, this cam loves to rev.
Old 02-14-2005, 02:16 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
As a TSP231/237 user, I suggest getting a TSP233/239.
Old 02-14-2005, 02:52 AM
Zach@Texas-Speed's Avatar
I put the 231/237, stage 2E MTI heads and ported/polished lingenfelter manifold on a friends M6 z28 and he made 446 to the rear wheels
Old 02-14-2005, 03:18 AM
LS198TA's Avatar
im going forged internals with mms heads and a tsp 237/242 magic stick/ls6 intake outta make some good #s
previous setup was a heads/cam combo from mms 224/224 .534/.534 went 12.05@113.72 in the dead summer with a ls1 intake and a th400
Old 02-14-2005, 12:01 PM
LS1TECH Sponsor
Steve Burger's Avatar
I made 445 at the wheels with AS 5.3 heads. It will idle rough but should be OK for a DD. I drive mine a lot onthe street when it's nice. I shif at about 6700. I agree the LS6 intake is a must. The better you let this cam breathe the better of you will be.
Old 02-14-2005, 12:39 PM
jrp
SN95 Director
jrp's Avatar
whats your tq and do you have a graph?
Old 02-14-2005, 12:44 PM
LS1TECH Sponsor
TQ was 409. No I don't have a graph as the floppy drive on Speed Inc.'s PC was broke. I will retune and redyno for upgraded injectors soon. Hope to get a graph out of that.
Old 02-14-2005, 12:47 PM
jrp
SN95 Director
jrp's Avatar
wow, thats the highest tq i've seen out of the 231/237, previously it was gomers 405rwtq.
Old 02-14-2005, 01:24 PM
LS1TECH Sponsor
Yeah, The first time around it was 435 and 408. I think there is a graph of that somewhere on here. There was a preload issue with the comp R lifters and the cam fell off at 6100 like a rock. After the preload was set right it pulled the new numbers and the curve is flat as a board to over 6800.
Need to get the weight down (working on that) and I hope to see 11.2 out of the car. Times in the sig are with a Spec 3 that was on the rivets. I am not sure how it ran that well after pulling the clutch. Upgraded to a 4F and will drop about 250 lbs before spring.
Old 02-14-2005, 01:34 PM
southern98ta's Avatar
i have tsp 231 cam and i drive my car every day and i do alot of driving . i put down 387/373 i like the cam needs some heads though
Old 02-14-2005, 03:05 PM
Nsty98LS1's Avatar
like i stated above i will get an ls6 intake soon probably in the next couple of months . i just have enough for the cam swap right now. thanks again for the help and suggestions
Old 02-14-2005, 04:07 PM
beachin99's Avatar
i love my cam! for me its very streetable! love the power it makes. but i too need an ls6 intake. would probably help a whole lot. if youre worried about the cams lack of torque just spray it and that should solve your problem. thats what im going to do!!
Old 02-14-2005, 08:21 PM
ujslost2's Avatar
Steve Burger,
I was wondering how much your heads were milled and did you have to flycut? Also how thick were your head gaskets? I have that cam along with a set of AS st2 5.3. I was worried about clearance. Thanks.
Old 02-15-2005, 02:43 AM
amwellls1's Avatar
I am from Pa also Pittsburgh area, so I have to deal with the emissions visaul as well as obd2 plug in. I have the 231/237, ppstg2 heads. stock throttle body, ls6 intake. slp headers and cats. m6, 12bolt with 4.10's. I went 11.72 @ 119+ 3770lbs on a mail order tsp tune. DA was 2800. No dyno numbers yet just some more info for you.
