turbo or charger
turbo or charger
a lot of guys seem to be going with turbos now. is there a reason why? i know the difference between the two, outside air or exhaust, but is there any pros or cons of one or the other?
thanks,
rob
thanks,
rob
turbo
thanks,
rob
thanks,
rob
In the broad sense of things I feel like it makes more sense to have a turbo because it not only forces the air in but also sucks the air out
Turbos do not suck the exhaust out of the engine. You should check the pressure of the exhaust before it enters the turbine housing. The heat of the exhaust and the pressure of the exhaust is what turns the turbo.
Also, FI is for fords? What ever. Thats like saying NO2 is only good for WW2 Bombers. FI is for who ever can aford real power, not just for Fords. Man I hate to flame but lets get our Sh*t together here.
Now that I am done flaming, I think, and its just MY OPINION, Turbos make for some of the best rides when driving them. They usually make more bottom end power, but you can offset that with other mods when running a supercharge. The truth is a roots blower is always there. It will make gobs of boost at Low RPM as well. No Spooling the thing up. But even it has its limits. It comes down to a few symple things that determine if you are going to buy a Turbo kit or a Supercharger kit. Money (turbo kits usually cost more in the end), room in the car (or how little room left over you are willing to put up with), availibility of the product, plug and play ease, and present mods or intended mods.
Superchargers can make alot of power with the right mods, so can a turbo, but if one of them were the best why don't the top fuelies use them? I think the Pro's use roots style blowers.
I think more often than not, a S/C setup will be simple and easy to setup compared to most turbo kits. The turbos usually make more power and have far more potential to make big power, but theres always turbo lag. A supercharger will make power right off idle, and it will grow proportionally as RPMS raise. If for no other reason, i think id go with a s/c so that I could still hear the nice rumble of the true duals.
another thing to consider....superchargers sacrifice more power than turbos. i remember researching this for a while when i was thinking of going forced induction. i know this is not an exact, cuz all applications are different, but i think with a s/c u will sacrifice close to 15-20% whereas with a turbo its closer to 5-10%. for example, for every 100hp u gain, u will lose 15-20hp with a huffer and only 5-10hp with a turbo. its kinda like a car losing power thru the drivetrain. ur motor power will always put out 15-20% higer than what your car actually sees at the rear wheels.
and as far as lag, i read that the way turbos are made these days, the lag is very minimum. the wheels are lighter, and spin faster cuz of this, and in turn...minimizing the lag.
I am a profesional Industrial Mechanic. I mainly work on Waukesha Gas Powered Industrial engines. They teach us that in a recipicating engine you use only one third of the energy generated by the engine threw rotation. One third goes out the flywheel to be utilize. One third goes out the exhaust. The last one third goes out the water jackets. A turbo uses up most all the exhaust energy and converts it to rotating energy Which then makes more exhaust energy and jacket water energy. Most aplications let the Jacket water energy go to waist. You do utilize some of it in the winter to keep the frost off your butt but most all of it is spent to the atmoshere. Energy is heat. So the use of a turbo makes the recipicating engine more efitient. There are engine that utilize blowers feed by turbos. Now they realy make power!!!
A supercharger is not considered to be effitient because it does not utilize the energy waisted in the exhaust. Turbos are not free power adders. They take energy to drive them. The more boost you use the more energy it takes to biuld it. Same as a supercharger. I have been told by mainy racers (non profetional) that turbos use less power then any direct driven FI, but I have never heard that claim at any Industrial Engine school.
Again, it all comes down to the things I stated before, Money, Availibility, Personal Preference, Space, Plug and Play, oh did I mention MONEY?
I personaly want to go turbo, but I can do what I want to do with a supercharger. The supercharger looks less expencive, less trouble to install, more availible, Taking up less space, and is more plug and play.
I have no idea wich is more reliable in the longevity department. That info would sway me one way or the other.
Good info Texas. You mentioned the Pro Stock draggers using SC, it's only because turbos are illegal at this point. BUT the NHRA is close to approving them for competition from what I understand.
Both have merits, the turbo IMHO is easier to upgrade down the road than a SC. It also allows "normal" driving habits to be used due to the lag. Kept my 2wd truck inline when some snow/ice made an apperance in Jan.
I would love to but here are the things making me think twice. The biggest thing is the money question, why should I shell out $7000+ when all I am looking to turn is low 11's. I think the instal would be a bigger pain in the rump then the supercharger (of course I have not done either so I realy do not know), I would be installing it myself. I just installed headers that I paid almost $700 for, they would be useless and have to be sold.
Thats my main problems with it. I would love a turbo or twins would be even better. I just have to justify the $2000 difference and the loss in money I would take from selling the headers.
Not trying to be a pain here, I realy wish someone could come up with a real good mind setting quote for me to push me over that line to go turbo insted of supercharger.
i think i found your problem
you are not being honest with yourself. low 11's will be slow once you get there and you will want a 10, then a mid 10 then you want to dip in the 9's.
my goal was 600rwhp and i would be happy.. now i am mad when i can't spin 5th gear from a roll
oh **** man, hey mightmouse, i just realized u are in richmond. im down here in va beach a couple hours from u. do u attend many events around here....cuz i dont know about much that goes around in these parts...???
hi wickid z. our car club has been participating in 'cruizin va beach' every april for the last three years.. cant say we are regulars down there any other time
our website is www.richmondperformancemusclecars.com
