So how screwed is my motor pt.2
A few months back I posted this about when I changed my oil: https://ls1tech.com/forums/generation-iii-internal-engine/238297-so-how-screwed-my-motor.html
Ever since that day I have been watching my oil like a hawk, i think i look at it more than my speed...
Anyhoo, the oil psi is still awesome, even when hot it's above 40psi. Cold idle is like 60something.
This past weekend I changed it again, no chunks like last time, just very very fine shreds of metal were on the magnet, i'd say <1mm long, and it wasn't alot, I think it was just normal wear, am I wrong? Also, drained the oil into 5 (of 6) qts, so it didn't drink that much.
I have a 408 on order but I am still leary about my 346, should I be or do you think i'll be alright?
thanks
-Steve
thanks
-Steve
i took some pics of the metal shavings on the end of the plug even though they didnt turn out very good just shows about how much there was:
Shavings on end of oil drain plug
picture without shavings
The chunks were magnetic? Obviously not aluminum... Were the chunks very small or larger and random shapes? I would definitely look into that... I previously worked in a machine shop and had seen nightmare engines where this had happened, and the client continued to drive...
