Where to get air compressor fitting(spark plug) locally?
Originally Posted by bigdsz
Don't laugh, but it's easier to stick a plastic straw down the spark plug hole of each cylinder and turn the crank over with a socket on the crank bolt till you reach TDC for that piston. I've been doing it for forty years.
This isn't the best method, but why buy the part? During my cam instal I had an air compressor and fitting and for some reason the pressure wasn't enough and the valves still slipped a little. I ended up rotating the crank and put the piston at tdc and then conducted the spring swap. If the valve fell it fell a very short distance and cause me zero problems. i know this isn't the preferred method, but in the driveway, worked ok for me.
