AFR 225 heads & flycutting.....
Old 03-19-2005, 06:43 PM
JF WS6's Avatar
Default AFR 225 heads & flycutting.....
Hey all,
I flycut my pistons with FFHP's flycutting setup that I believe used a junk 5.3 head. Are my flycuts going to line up with the valves on an AFR head? I was thinking I wanted to maybe get a set of 225's to run on my aggressively set up 346, but I'm not going to if my flycuts won't match the valves..... any info. is appreciated. Thanks!
Old 03-19-2005, 06:47 PM
Squintz Palladoris's Avatar
You should be good to go.
Brad
Old 03-19-2005, 07:04 PM
JF WS6's Avatar
Brad
Thanks for the quick reply. I was just unsure since I read that LG was using specifically a junk AFR head to flycut pistons on cars that were getting AFR heads installed. Wanted to make sure.......
