Rockers OK ... harmonic balancer ????
Well, took off the valve covers and the rockers were all tight with the correct torque.
Rev'd the engine and I think I found the area where the noise is coming from ... could be a pully or a belt, however, it sounds like it's coming from within the harmonic balancer hub, right on the front of the engine, that bolts onto the crank (maybe it's pressed on ... not sure) .
What the hell could be bad in this area of the engine???? It felt like it's on good and tight.
