need Cam help with my AFR 205 Heads!
Old 04-13-2005, 08:54 PM
disposer's Avatar
Default need Cam help with my AFR 205 Heads!
i have a 2000 Camaro with full Bolt ons and 3000 Stall TC and 90mm LSX
i have just recieved my AFR 205 Heads with valve springs and retainers and stock valves..... (Stock bottom)
what do you think about the MTI G1 cam (228/232 .. .588/.575 .. 113 LSA)?
and what is the best Cam that may perform best on my set up for both N/A and N2O ? (150 shots wet NX)
Thank you guys
Old 04-14-2005, 06:11 AM
BTL FED's Avatar
That looks real similar to a cam I used to run in my car, it was a 228/234 588/598 it ran real good on motor and on the bottle. I liked the cam alot, this one looks like it would do pretty well too. If you are in Doubt call Alan at FMS and he can get you all hooked up
