Cam install question!!!
Old 04-13-2005, 09:03 PM
bcrishon's Avatar
Default Cam install question!!!
Do you have to remove the oil pan on a 99 LS1 to replace the cam?? Am planning on doin it this weekend and if so I need to get the gasket! Thanks for the help!!
Old 04-13-2005, 09:30 PM
NviouSS's Avatar
nope. check out ls1howto.com if you need directions.
Old 04-13-2005, 09:44 PM
01_SuperSlow's Avatar
You will only have to loosen the oil pan if you need to take off your oil pump. And the gasket is reusable. Read the cam install write-up in ls1howto.com and you'll be good to go.
Old 04-14-2005, 06:20 AM
bcrishon's Avatar
Thanks for the help guys!!
