uh did i mess anything up?
Old 04-29-2005, 02:26 PM
burnout04's Avatar
Default uh did i mess anything up?
hey, last week i was passing a car on a country road and didnt realize i was going so fast and floored my car in second to the point where it hit the fuel cutoff. Now common sense says the fuel cutoff is there at the point where you could break something if u go past it, but could I still have damaged something? Seems to be running ok.
Old 04-29-2005, 02:33 PM
cr0y's Avatar
The fuel cut off? Some other member correct me if i am wrong, but shouldn't the car have just bounced off the rev limiter?
oh, and more than likely nothing bad happened....it is sometimes hard to say though
Old 04-29-2005, 04:19 PM
Red99TA's Avatar
that's what the rev limiter is there for...to protect your engine from over-revving. The problems come when people mechanically overrev like accidentally shifting from 3rd into 2nd instead of 3rd into 4th when going like 70 mph plus (this forces the rpms to shoot up and the rev limiter can't do anything about it) which leads to bent pushrods. You should be fine.
Old 04-30-2005, 11:57 PM
soslo's Avatar
the fuel-cutoff is the rev limiter...
and no, you probably didn't mess anything up. It happens all of the time.
Old 05-02-2005, 09:41 AM
GuitsBoy's Avatar
Lol, my engine's seen the revlimiter a good 2 or 3 dozen times for a bunch of different reasons... 74K and no mechanical issues.
Old 05-02-2005, 10:11 AM
Cal
Cal's Avatar
Same here, and mine is at 7000 rpm.
