Anybody running Comp 623-16 valve locks?
Old 05-02-2005, 01:28 PM
94bamf's Avatar
Default Anybody running Comp 623-16 valve locks?
"The COMP Cams® LS1 High Performance Valve Locks are 7-degree units that contain the same precision tolerances and superior strength as that found in COMP®'s patented 10-degree Super Locks™. The LS1 High Performance Locks are manufactured from machined steel and are idea for high performance stock and most racing applications."
I am guessing most guys are running the stock valve locks, but Comp sells these, and I can get a set for around $30. Worth it?
Are the stock locks pretty good?
Old 05-02-2005, 01:41 PM
BrentB@TEA's Avatar
we have never had a stock lock failure.
Old 05-02-2005, 07:51 PM
94bamf's Avatar
Anybody know where you can buy the stock locks on the net?
I would just order the Comps, but my luck, they are not as good as factory stuff......
Old 05-02-2005, 08:56 PM
bigdsz's Avatar
FWIW I recently installed machined Manley Bead Locs.
Quick Reply: Anybody running Comp 623-16 valve locks?
