Interesting Flow Data....(Long thread)
Old 01-06-2010, 10:25 PM
  #281
SHovV's Avatar
how would the heads do on my 427ci LS6......with a 92/92 & F1-A
Old 03-17-2010, 08:51 PM
  #282
Flow Wizard
Tony Mamo @ AFR's Avatar
Guys,
I need to visit this thread more often....I apologize about that.
Im short on time now but will update you on the 245 shortly and a recent 225 head I did some work on with really nice results.
Give me a few days and I will get back here with that info....245 is days/weeks away at best.
-Tony
Old 04-25-2010, 04:54 PM
  #283
SVO_Steve's Avatar
Hello, I just signed up today so I guess I'm a noob. Anyways I have been porting heads [many different kinds] for a while and I recently did my first set of LS1 heads for someone and paid to have an intake and ex runner flowed. They were 6.0L "317" truck heads here are some before numbers I found online of the exact casting... dumbass I am... should have flowed them before, the guy didn't seem all that interested in doing that, till they were done...
Casting Number 317, 035
Head: 2001+ LQ4 and LQ9 6.0 Liter Truck
Material: Aluminimum
Part Number:
12562317 -LQ4
12572317 -LQ9
12572035 -LQ9
Combustion Chamber Volume: 71.06cc
Compression Ratio: 10:1 LQ9 Flat top pistons
Compression Ratio: 9.6:1 LQ4 Dish piston
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Stock Head Flow Numbers
Chamber 71.06cc----0.100---0.200---0.300---0.400---0.500---0.550---0.600
Intake 210cc----------66------142-----196-----228----236---238----240
Exhaust 75cc----------59------104-----137-----155----167---173----177
Here is after #s. Stock valves still etc.
INT
.200" - 147.3
.300" - 212.6
.400" - 251.5
.500" - 272.4
.600" - 271
.700" - 272
EX
.200" - 117
.300" - 154.5
.400" - 180
.500" - 201
.600" - 219
.700" - 222
& some pics...
http://ohreally.mnsi.net/ls1bowl1.jpg
http://ohreally.mnsi.net/ls1bowl.jpg
http://ohreally.mnsi.net/ls1bowlported.jpg
http://ohreally.mnsi.net/ls1intrunner.jpg
http://ohreally.mnsi.net/ls1intported.jpg
http://ohreally.mnsi.net/ls1exrun.jpg
http://ohreally.mnsi.net/ls1exrunported.jpg
http://ohreally.mnsi.net/ls1headex.jpg
http://ohreally.mnsi.net/ls1runnersported.jpg
http://ohreally.mnsi.net/ls1done.jpg
I'm just wondering how I did.. you can't see from the angle of the pics, but I did make a hole where the rocker bolt boss was.. I made a plug for the hole and then blended it, and had him test it w/o the plug and with.. and the difference was NIL.... Thanks.
Old 06-01-2010, 01:29 PM
  #284
LS6
LS6's Avatar
Nice thread
wish to be sticky
it contain good information
Old 07-31-2010, 05:58 PM
  #285
Cheatin' Chad's Avatar
Any new info?
Old 12-20-2010, 09:30 AM
  #286
Evan G's Avatar
Default Heads and Cams
What would you recomend when it comes to brands of heads and cam packs? and is Trick Flow 500 HP GenX package a waste of money or a good investment?
Old 04-07-2011, 02:08 PM
  #287
Abuckeye's Avatar
That's a good increase in flow.
Old 04-13-2011, 12:53 AM
  #288
Mattsv8's Avatar
Tony if I had a set of l92 heads for a 6l turbo setup could u port them for good numbers. I wana run edelbrock vr intake and carb. Would b blow through. Or is it cheaper and smarter to just buy a new set of afrs? I have afr 210s on my stock 350 block turbo setup running 8.80s at 153 with the out of the box race port not comp. And 8.4:1 w 15psi and t88 on pump e85 in a s10 that is 3600lb. Afrs flat make power.
Old 08-25-2013, 09:36 PM
  #289
hotstreet's Avatar
Im Loving these rite ups
Old 03-04-2015, 09:20 PM
  #290
fordkilla2000's Avatar
Default exactly
It's like they're testing the first casts and then the commercialization alters numbers.. Nothing against anyone and I also forget the name but I've found heads that has similar numbers but cheaper than AFR
Old 06-19-2018, 12:45 PM
  #291
Phil coppney's Avatar
Default 317 heads
Does anyone have flow numbers for 317 heads ported by a professional? When I say professional here is the bar. My guy has a machine shop that is 3rd generation, been working heads since the 40's. Been porting them since the 70's.
I know the numbers will not be an exact match, just trying to get an idea without yanking the heads off.
Old 06-19-2018, 01:26 PM
  #292
Received 3,022 Likes on 2,353 Posts
TSP has flow #'s for their port jobs. Go to where they list their Cathedral Porting Service and there are flow #'s for both Stage 1 (stock valves) and Stage 2.5 (2.02 intakes)
Old 06-19-2018, 02:11 PM
  #293
Perfect! Thanks, better flow than I would have guessed.
Old 06-19-2018, 02:25 PM
  #294
Glad I could help! Yeah, I've always heard TSP does a good port/valve job, especially for the money.
Old 03-07-2020, 12:08 AM
  #295
bortous's Avatar
I like this thread.
Nice to see in 2020 that big headed cathedral head came to fruition and is a monster
The following users liked this post:
G Atsma (03-07-2020)
Old 04-25-2020, 08:19 AM
  #296
msystic27's Avatar
is there any non ported LS1-LS6 heads in the data above that i can assume would be close to my 2002 ss
G Atsma (04-25-2020)
Quick Reply: Interesting Flow Data....(Long thread)
