Piston to Valve Clearance ??? for T-Rex
Old 05-15-2005, 09:20 PM
Evans752's Avatar
Default Piston to Valve Clearance ??? for T-Rex
I have a Stock LS6 Motor Including heads, was wanting to go with Trex cam but dont know if I will have clearance problems?
Old 05-15-2005, 09:22 PM
Josh's Avatar
As long as the heads are completely stock you should be just fine.
Josh
Old 05-16-2005, 09:04 AM
GuitsBoy's Avatar
Its my understanding that the T-Rex was designed to be just about as big a cam as will fit under stock heads.
Old 05-16-2005, 09:22 AM
blkZ28spt's Avatar
Pretty much. It's huge!
I am far from an expert, but I'd wait for somebody who can verify it will fit under LS6 heads as well as LS1. Or try and find it through search. I don't know. BUT what I do know is that the LS6 is listed as having a slightly smaller combustion chamber. 64.45 cc vs the LS1's 66.67 cc. Given that, it might be a tighter fit.
Old 05-16-2005, 09:35 AM
GuitsBoy's Avatar
I believe that the smaller combustion chamber is due to the shape of the chamber. I do not believe the valve seats are any closer to the deck. But I am not an expert either, and I would agree with blkZ28spt's suggestion of looking for someone who can verify that itll fit. You could always call up thunder.
Old 05-16-2005, 10:52 AM
dug
dug's Avatar
I emailed thunder the same question and they said it would be a tight fit but should clear.
Old 05-16-2005, 01:43 PM
Evans752's Avatar
Thanks everyone for your advice, if anyone else who has a ZO6 with this cam please let me know about your car.
Thanks again
Old 05-16-2005, 02:31 PM
F1_SS's Avatar
On zo6vette.com there was a guy who thought it would fit and ran it anyway on his zo6 with ls6 heads, few miles later he is rebulding the motor because valves were kissing the piston. FLYCUT! even if it clears, FLYCUT, that way you know it will clear and not be so tight.
Old 05-16-2005, 04:06 PM
Camaroholic's Avatar
With this cam, clearances are so close that it MUST be degreed upon install (you must get an adjustable timing gear set), and installed to spec. Lining it up dot-to-dot and calling it good is not acceptable. Gotta be careful.
Old 05-16-2005, 04:33 PM
dug
dug's Avatar
btw there is a member with this cam in a z06 with 1 7/8" kooks headers making 450rwhp.
Old 05-16-2005, 05:02 PM
blkZ28spt's Avatar
There is a reason that people didn't think the G5X3 would fit on a 112. It used to be borderline common knowledge that the X3 wouldn't fit on a 112. Or so it seemed......
Quick Reply: Piston to Valve Clearance ??? for T-Rex
