which heads...
which heads...
i will be startin to build a 6.0 before to long and was wonderin what kind of heads i should go with. the motor will be stock 6.0 shortblock with upgraded rod bolts, bearing, etc...the cam i am probably gonna go with is either gonna be the thunderracing 230/224 .575/.563 111 LSA or the 236/230 .602/.575 112 LSA. Now what size heads should i look at doin? 5.3's, 5.7's or 6.0's. also which ever heads u recommend how does this setup sound to u?
Originally Posted by jrp
which shortblock, lq4 or lq9? and what type of setup are you looking for?
