need lots of help
Old 05-27-2005, 10:41 PM
1fstbird's Avatar
Default need lots of help
i have a noise coming from the passenger side head. i pulled the valve cover to check the springs and nothing is broken. any suggestions before i put it back together would be tremendous. i did however notice that the number four cylinder had a loose rocker arm that may have been the problem but will not know until i get it back together. all the pushrods are as straight as an arrow. also what is the torque specifications on the rockers. thank you very much!!!
Old 05-28-2005, 01:12 PM
ILLWS6's Avatar
Apply Loctite to all the rocker bolts and reinstall all the rockers. Torque the rockers to 22lb/ft, rotate the crankshaft 180 degrees and double check the torque on all the rocker arm bolts.
