premiter bolt valve covers to center bolt style
i have a 98z i bought a set of ls6 ported heads and now the header are center bolt style. my question is...will the harness on a center bolt valve cover plug rite into my main harness. are the connectors the same?
SN95 Director
no problem. i used used the bolts that bolt the coil packs directly to the 98 covers for the coil pack braket and i used two of the perimiter bolts from the valve covers to mount the coil to the valve covers. that way all i have to do is remove 4 screws total and i can remove the coil packs with ease.
