Ideal Na Compression Ratio/ Head Question
I was looking at getting some heads for my car (4000+ stall, 4.11s, 28" tire, 228/232 cam) but Im a little confused about what compression ratio to run. For a NA 346 setup is it ideal to run around 11.1? Is it possible to get a set of LQ9 6.0 ltr casting 317 truck heads to make that compression? If so, what would have to be done to them? what gaskets? Will they clear a big cam?
That's the only bad thing about 6.0 heads. You have to mill the crap out of them to get compression. If you want to stick with the 6.0 casting, you should get a set of the Patriot 59cc castings. You can buy them bare with nothing more than the chambers cut. The welded design allows you to keep all you P/V clearence, and still have the larger ports. Then you can have whomever you want work them over.
LS1 Tech Administrator
If you're running pump gas, you'll want to keep your dynamic compression at or below 8.5 to 1. You can hit that with stock static compression of 10 to 1 or with a static compression of 13 to 1. It all depends on the valve events of the cam you choose.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
