Which valvesprings can I use?
Which valvesprings should I use?
Hey all. I just purchased a Thunder Racing Custom "Reverse Split" Camshaft - 230/224 .575/.563 111 LSA 2200-6800 RPM Power Band - along with some trickflow hardened pushrods. I'm on a pretty tight budget and I still need to get some valvesprings and possibly titanium retainers. I've heard the Comp 918's are the way to go, but I have found some other springs cheaper, but not sure if they will work, or if these cheaper ones won't last as long. While browsing around SDPC I found these springs from Lunati. Would these work with stock retainers or would they require the titanium retainers?
http://www.sdpc2000.com/catalog/1797...ve-Springs.htm
Also do I need a cam gasket or something like that also? I could really use some help with this.
Thanks!
Al
Thanks!
Al
I'd go with 918's (no expeirence with the lunati springs) and titinium retainers, but the tit retainers are not necessary just a good idea. I'm not sure about 99's, but I know on the later years you can reuse the stock gaskets if you don't damage them while removing stuff. I'd just buy a gasket kit. Don't forget a new balancer bolt.
Thanks for the info. How high can I rev the engine if I keep stock retainers? How high with the titanium? What's a balancer bolt? Can I get one of these at a local car part store or do I need to order one? (sorry I don't mean to sound stupid.)
Ok I have 2 possible deals going right now....
From dealer 1
We do offer a valve spring kit from Manleythat will wotk very well. They are good to .600 lift but are not a beehive spring. This kit will include: valve springs, tit retainers, and spring seats. This would cost a bit over $200
Or a deal from dealer 2 for a Comp Cams 918 springs with Titanium Retainers for almost $100 more (still a good deal though).
Are these Manley ones ok and why would I need spring seats?
From dealer 1
Just get the 918's with Ti retainers, they are a VERY good spring.
Be sure to read www.ls1howto.com
They have a nice F-body cam swap writup. I have a link in my sig to a post I made after swapping my cam/springs that fills in some of what ls1howto leaves out, and some advice.
Originally Posted by calongo_SS
balancer bolt is the bolt for the crank pulley. I got the ARP bolt and it was worth the money.
Are you referring to this?
Longer crankshaft pulley bolt, M16 x 2.0 pitch x 120mm long
(quoted from ls1howto.com)
Where can I get this?
And yes I did get a nice offer for the 918's and retainers. Probably going to go with that.
