need help goin nuts here
Old 07-02-2005, 11:11 PM
ls1powrdta's Avatar
Default need help goin nuts here
ive been chasing this slapping noise in my engine.cant figure out whats goin on.ive recently installed harland sharp roller rockers 1.7,patriot dual springs and chrome moly push rods.ever since the install i am hearing a loud slapping noise when i increase the rpms.i found some of the rockers were hitting the valve covers and heads so i ground them down to clear.when i first started this i put 7.45 pushrods and the car wouldnt start.could i have really screwed something up havin done that.ive checked all the plugs and wires.none are loose.everything in the motor is stock in exception to the named above.any help would be greatly appreciated.im hopin to hit the strip this coming wed but not sure if i should chance it with this noise.thanks in advance
Old 07-02-2005, 11:38 PM
ls1powrdta's Avatar
by the way i put the stock rockers in today and the slapping is still there.im lost
Old 07-02-2005, 11:51 PM
PREDATOR-Z's Avatar
You may have damaged one or more lifters.
Old 07-03-2005, 10:49 AM
queso's Avatar
lifter
Old 07-04-2005, 01:57 AM
ls1powrdta's Avatar
is there a way to tell if i have.ive checked all the rockers.none are lose.
