CAM Question Got a 224/228 112
I have the idle set at 975 but when I drive it goes up high and then when I slow to a stop or start braking it revs up while slowing down. And if I let off the gas at about 30 or 65 mph the car drives it self, its like cruis control. Any ideas, I think I have to get it tuned better. Maybe i should tell them to have it idle higher in park or in drive and lower the idle in gear. Thanks
Need Help?
I am trying to find a solution to this, anyone got any ideas, cars idle goes from about 400 to 950 back and forth while braking or slowing down and is like rocking back and forth?
1 Post
BTW, did you drilll the throttle body at all. This is the cheapa$$ fix for the same problem. LS1howto.com has a description of this under their cam install section.
I had it tuned and then i brought it back to get it re-tuned and solved the problem, increased the idle in park and neutral and it helped it out a lot. But for some reason my SES light came back on???
