Cam install extras?
Old 07-11-2005, 08:20 PM
00BadassTA's Avatar
Default Cam install extras?
I have a 00 ta with about 44k miles and I am wanting to install a hot cam. Should I replace the oil pump and timing chain or is it not necessary.
Any help would be great.
Old 07-11-2005, 08:31 PM
blkZ28spt's Avatar
Search button!!!
LS6 style oil pump, LS2 timing chain (buy from SDPC-->)
Of course the springs, pushrods, etc are assumed.
Out of curiosity, why the hotcam?
Old 07-11-2005, 08:47 PM
dragonZ28's Avatar
I would do a ported LS6 oil pump, front main seal, and LS2 timing chain. You don't need valve cover gaskets, front cover gasket, and you can even get away with re-using your water pump gaskets (Replace anyway to be on the safe side).
Old 07-11-2005, 09:57 PM
jmm98LS1's Avatar
That's what I did.
Old 07-11-2005, 11:12 PM
ChaseSS's Avatar
unrelated but you might want to look at some more cams...nothing against the hot cam but you can find some with similar characteristics that put out larger numbers
