how much oil
how much oil
how much oil does your car go threw between oil changes. i just checked mine and it was all the way in the add section. there are no leaks at all.
7 Second Club
what mods do you have?
mods are: ls6 intake, comp 224 cam, comp pushrods, comp 918 valve springs, ls6 ported oil pump, p/p tb, MAF ported ends, rollmaster timming chain. those are all the power mods, oh, and the NOS 5177 kit, and i do get on it alot, but still it seems like once a month i have to add a quart of oil to it.
7 Second Club
check valve stem seals... the same thing happend to me about 4 weeks ago
oil consumption
If you dont have a catch can, you might want to look into the intake and see if its oily at all. You are probably pulling it through the pcv, and check the pcv and clean or replace if necessary. When i put my catch can on my intake was very oily, and that was before the blower. Once installed i never use any oil. I change it more often than most but it is never down.
