what cam is best 220/224 113- 220/220 112- 224/224 114
I'm trying to get the most out of my cam for emissions in California, I think its crap that you can't run longtubes just because of visual, so I'm going to get some and say to hell with them, but obviously the cam is more difficult to pass if its to big. I've done some research on here on what will pass, some say 224/228 114 LSA has passed which has -2 overlap, but more common I see the biggest that will safely pass is the 224/224 114 LSA with a -4 overlap. Since it is clear that this cam will pass I see no reason to go with more overlap only to find out it won't pass. So I've decided to go with a crane cam custom cut to my needs. All of these cams 220/224 113- 220/220 112- 224/224 114 with 561/561 or 551/551 lift depending on what I can get away with using LS6 springs have the same -4 overlap, but will one be a better choice over the others? I know there might be slight differences between them, but not to sure what they are. I'm not worried about rough idles or surge, just mainly looking for the best setup and power for my daily driver. If I could, I'd go much bigger like the ASA GM cam, but lovely **** California says otherwise.
LS1 Tech Administrator
Of those choices, the best one is the 224/224 114LSA cam if you're running headers. If you're still running stock manifolds and cats, you'll probably want a bigger split between intake and exhaust duration, like the CheaTR cam. It has -10 degrees of overlap, but will rpm to 6800.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
I would do the 220/224 or the 224/224 cam.
Like said above if yor exhaust is holding you back use a cam like the cheater cam.
Personially I would use the cheater cam.
Leave the exhaust stock and run a 918 spring.
Pass emissions, look stock, sound mostly stock and have a much more fun car.
Call Thunder and talk to them about it.
JZ
JZ
