Opinions wanted
Location: Your girl's back door giving her the long stroke while you're at work
Opinions wanted
I am going to Iraq next month and I'm planning a couple of mods for the car when I get back. A dyno tune will come shortly after.
Futral Motorsports
#1 F13 on 114 LSA
#2 PRC Dual Spring Kit (FMS Chromemoly Pushrods)
#3 GM Gasket Set
Byun Speed
#1 TCI Streetfighter (3000-3400 stall)
#2 B & M Trans Cooler (24,000 GVW)
#3 Trans-Go Shift Kit
Does this sound like a good set-up to go with the mods in the sig? Remember this thing is driven about 200-250 miles weekly. Any other suggestions?
Futral Motorsports
#1 F13 on 114 LSA
#3 GM Gasket Set
Byun Speed
Should I also replace the lifters while everything is out? The car has around 53K on it. Would this be the easy way to knock out the oil pump and chain in one punch?
http://byunspeed.com/catalog/product...6b0aaf3fda7d12
Dumb Ass Vette Moderator
IF you are installing a cam, I would do a ported oil pump and upgrade the timing chain.Installing anyone one of the three requires removing the front cover and harmonic ballancer. The cover and balancer are a PITA, so it makes sense to do all three at once.
Other than that, the cam and tune should do well with the mods you currently have.
Good luck in Iraq and thank you for your service
Keith
Keith
