Is a .100 flycut about right?
A friend and I are installing a Comp Cam XER 242/248 .610/.615 111lsa. AFR heads milled .034, 2.02 valves, using .040 Cometic gaskets. Does flycutting about .100 seem about right for the intakes? Also what about the exhaust valves, they are the 1.60's. what should they be flycut? Thanks
We've taken measurements till we are blue in the face, We were gonna start with .080 but the Isky tool collar was fkd up, so we cut a little deeper than we were going to initially. We have the cam in with the degree wheel installed.WE are waiting to get the heads back. We thought we would start cutting before we got the heads back to save a little time. A number of shops told us at least .080 minimum so we figured .100 would be OK. Any thoughts?
