Valve upgrade
Old 08-17-2005, 12:47 AM
Crazy Man's Avatar
Default Valve upgrade
What would I have to change to put bigger valves in a stock head? And could someone tell me whats size valves you guys recommend.. Thanks
Old 08-17-2005, 12:55 AM
Full-Force's Avatar
Hey Tim, its Mike. That will have to be done by a machine shop. Well, you can put the valves in easy but the heads have to be cut for the size valve you have. Not to mention you will want to have atleast a 3 angle or 5 angle valve job done. I tell you what. You may end up with over 500 bucks worth of parts and machine work. I know a little about whats been done to your heads so I know where you are going with this. The PP stage 2 heads with the REV valves start looking good to me at under 1100 bucks.
Old 08-17-2005, 01:16 AM
Crazy Man's Avatar
Thanks mike! Yeah I was reading where a guy put down 430rwhp with the new cam im putting in and all he had was oversized valves in the heads.... You goin to run yours this fall? If so ill see ya there hopefully greer if I get a cage if not shady side...
Old 08-17-2005, 11:03 AM
Full-Force's Avatar
I ran it last Thursday. Thing would only run a 8.22. I have M/T ET Street Radials they spun like a Nitto. Track just didnt have any rubber on it. My 60' was 1.99 - 2.07.
I Just put my 4.10 gear in yesterday. Probably the best mod so far. It woke the car up something fierce.
Old 08-17-2005, 11:06 AM
Crazy Man's Avatar
Where did you run it at?
Old 08-17-2005, 06:34 PM
00SS4780's Avatar
Hey Tim, you got that thing in yet?
