HELP!!! oil everywhere!!!!
Old 08-27-2005, 11:58 PM
FartCanPolice's Avatar
Default HELP!!! oil everywhere!!!!
Ok got cam installed everything done perfect, torqued to spec ect.... drove hour home= ok.....get home and theres like a oil residue all over my back bumper and Like 1 qt in my crankcase...look under the car and the underside is COATED in oil....doesnt start till about where the trans is...what the hell could have happened!!!???
Old 08-28-2005, 12:04 AM
Nittany_marine's Avatar
Did you take anything apart under the motor? Oil pan? Something like that?
I'll keep an eye on this thread, and see if I can help ya out at all tonight....
Old 08-28-2005, 12:05 AM
nope, we didnt change timing chain, nothing under the motor @ all
Old 08-28-2005, 12:08 AM
nothing at all up front on the motor? At all?
Old 08-28-2005, 12:10 AM
on the front, just pulled banancer off, replaced w/ brand new timing cover seal and pressed back on balancer w/ special tool
Old 08-28-2005, 12:12 AM
JZ'sTA's Avatar
Guess that means you dont need me to install that cam for you anymore.
Glad you let me know......
Good luck with the oil problem. Did you change the oil?
Maybe the filter isn't on correctly.
Old 08-28-2005, 12:13 AM
we got it done ok just i think maybe the timing seal didnt set right (should of we hammered it in w/a block
Old 08-28-2005, 12:14 AM
Not trying to be a smart *** or anything, but did you get your oil changed recently? Check the filter tightness. Ive seen that before a few times. Sometimes old seal is still stuck on there.
Also, were you beating on it pretty good on the way home?
Sorry man, I got it done closer to home
Old 08-28-2005, 12:15 AM
we changed oil but not filter because the chode that put it on before put it to tight and i didnt have a filter wrench handy, so I kind of ruled the filter out
Old 08-28-2005, 12:16 AM
no kept rpms down (under 4k @ the MOST for like 1 second)
Old 08-28-2005, 12:20 AM
JZ'sTA's Avatar
Damn that sucks. I am sure it is a simple fix, but might take some time to find.
Tomorrow you need to start the car and find the leak, then it will be easier to tell you how to fix the problem.
JZ'sTA's Avatar
Thats cool, just wish you would have sent me a update.
Again good luck with the fix.
Old 08-28-2005, 12:22 AM
i Thought it was just burning a oil but a almost drained crankcase and underside coated in oil had me believe otherwise, especially since its before where my exhaust cuts off under the car
Old 08-28-2005, 12:23 AM
Is the plug in?
plug is in and tight
Old 08-28-2005, 12:24 AM
Also, if you were trying real hard to get the filter off, they have a tendency to tear a little bit. Maybe you have a 1" or so tear in the filter? That much oil loss with the vehicle still being able to run fine, makes me think its something petty, or stupid thats leaking.
Old 08-28-2005, 12:25 AM
is there like a rear seal that could have went? it "seems" to start after the motor (oil everywhere) but around the tranny, and yes im positive its motor oil
Old 08-28-2005, 12:26 AM
yea it ran fine even while pulling into parking space (of course I could smell a light oil smell) but that we dripped a few drops on exhaust. I wiped off the bumper the 1st time then the 2nd time i saw oil there i knew something was up
