Cometic Question
Old 09-12-2005, 09:27 AM
89lx-ls1's Avatar
Default Cometic Question
I know this is a pretty big subject but just asking,
Spray the head gaskets with copper spray or not??
Thanks in advance.
Old 09-12-2005, 10:16 AM
89lx-ls1's Avatar
ttt>>>>>>>>>>
Old 09-12-2005, 10:27 AM
Restricted User
CAT3's Avatar
I think I will be spraying mine, first time to install them and dont want to have to do it all over again.....call me "internet hype on Cometics leaking scared."
Old 09-12-2005, 10:33 AM
as35thss's Avatar
I would spray them. I sprayed mine, with no problems. You take a big chance if you don't.
Old 09-12-2005, 11:20 AM
smask04C5's Avatar
lightly sprayed mine, no problems
Old 09-12-2005, 11:21 AM
Mirek's Avatar
No spray, no problems.
OEM headbolts.
Old 09-12-2005, 11:34 AM
89lx-ls1's Avatar
So 3 spray and 1 no spray I guess I will spray mine and I am also using arp studs.
Old 09-12-2005, 12:07 PM
frodo84's Avatar
Any downside to using the copper sealant to anyone's knowledge?
Old 09-12-2005, 12:13 PM
bigdsz's Avatar
If the Cometics are not sprayed supposedly they are reusable, which I think some would question. Sprayed, not reusable.
Old 09-12-2005, 12:46 PM
ArcticZ28's Avatar
Red face
They actually are reusable even if you sprayed them, a lot of people have reused em. The only downside to spraying them is cleaning the crap off the mating surfaces each time you take the heads off and put em back on to get a good seal. If you don't foresee that happening too much, then go ahead and spray them. But, if you are gonna be pulling them frequently, might as well try it without spraying b/c you're gonna be pulling them a lot anyways so it can't hurt. I personally sprayed mine the first time and haven't had any problems. I played it safe b/c I didn't see my heads coming off anytime soon. Up to you though.
Old 09-12-2005, 06:34 PM
LS1 Swapper's Avatar
Make sure you really clean the block and heads of the old gasket, I mean with a razor or you'll probably leak. Also make sure you put them on correctly. No sealant is needed or recommended.
Old 09-12-2005, 09:10 PM
S10xGN's Avatar
Billy Anderson over on Turbobuick.com (who builds 8 second turbo regals) says his first install is dry, and he reuses up to four times with the reuses being sprayed with a light coat of Hylomar.
Old 09-12-2005, 09:37 PM
ArcticZ28's Avatar
Well using them a 3rd time with spraying is like using them the first time with spraying. So, that just proves you can do it either way, but if you want to play it extra safe, then spray it. They are reuseable both ways.
Old 09-12-2005, 09:44 PM
Restricted User
2001 Pewter WS6's Avatar
OEM headbolts.
Ditto here...
Old 09-13-2005, 03:54 PM
Dixit's Avatar
I didnt spray mine and they are leaking slightly which Im removing the heads again this week to probably just ditch the Cometics and go back to GM MLS gaskets.
Dixit
Old 09-13-2005, 04:04 PM
Z06-Dave's Avatar
No spray no leaks...so far...........
Old 09-13-2005, 04:49 PM
denscor's Avatar
do you spray the mls ? or put them on dry!
Old 09-13-2005, 06:08 PM
Byter's Avatar
I didn't spray them when they were new (i.e. the first time I used them). I sprayed them the second time. No leaks either way.
Old 09-13-2005, 06:13 PM
smask04C5's Avatar
Spray lightly and reuse several times, as long as deck and heads are clean and flat
Old 09-13-2005, 09:00 PM
89lx-ls1's Avatar
Thanks guys they are installed now we will see some time soon when ever I get the powerhouse in my car
