ls1 vs. ls6 heads
Old 09-19-2005, 06:59 PM
Hawkeye's Avatar
Default ls1 vs. ls6 heads
I have a set of 99 5.7 LS1 heads that were ported by Absolute Speed (stage 2)....They made 407 hp/395tq with a thunder 224 cam/kooks . My Question is Im gonna be getting a 01 LS6 motor from a low milage vette in the next week or 2. What would be the HP/TQ difference if I put the 224 cam in the Stock head LS6 motor????
I'm hoping I can just slide the cam in the motor and install some valve springs and go....Or should I stick the AS heads on the LS6 block????
Old 09-19-2005, 08:36 PM
ls1wannabe's Avatar
i would say look to see some less power if you use the ls6 heads but you can always port them
Old 09-19-2005, 09:35 PM
silverTA2002's Avatar
Ported LS1 heads will flow WAY better than stock LS6 heads.
Ported LS6 heads could make 10-15hp more than the ported LS1 heads.
If I were you, I'd throw the LS1 ported heads on the LS6 block, and sell the LS6 heads.
Old 09-19-2005, 10:27 PM
SUX2BU's Avatar
i knew a guy that had GTP stage 2 heads i belive. never dynoed good. he swapped out for some stock LS6 heads and gained 10 rwhp.
Just cause they are ported doesn't mean it a good port job.
Old 09-20-2005, 01:11 AM
SS1875's Avatar
If, I were you, I would sell the LS1 heads and have the LS6 heads ported.
Old 09-20-2005, 05:37 AM
transam1998's Avatar
Same heads, my car dynos fine.
Old 09-20-2005, 07:22 AM
vettenuts's Avatar
Keep the LS1 heads. The 2001 Vette heads didn't have any of the advantages of the 2002 heads, i.e., lightweight valves, etc. I would re-use your current heads.
