Crane quick lift cam, need Dual Springs?
Old 09-25-2005, 05:55 PM
Gotcha's Avatar
Default Crane quick lift cam, need Dual Springs?
I could use some advise on valve springs.
I Got a 2005 Silverado 4x4 5.3
Added CAI, catback with Lingenfelter GT2-3 cam and Z06 springs a couple months ago. Truck runs great! I originally wanted a cam that would work with stock programming and the GT2-3 ran great. (I didn't have much loot at the time and it looked like programming would be atleast 400.) Then heard about wait4me and he's only a couple hours away so took the truck to him for a tune and really runs great now.
Well fast forward a couple months and I've gotten a little carried away with other mods: lowered, custom wheels etc..
Now I want a little more cam in it, something with a little attitude (lope). I got a Crane 216/224 .551/.551 115lsa. I planned on just swapping cams and keeping the Z06 springs but looks like The Z06 springs arent up to spec (90#/294#), Crane cam card calls for 112# @1.800 and 303# @1.270. Crane recommends their dual spring setup which appears to need new seats, valve seals and retainers. All that is gonna add up $$$.
I was thinking about using comp 918 springs 130#/318#, that would be cheaper/easier or should I spring for the duals?
Also, can someone look at cam card and tell me how many degrees of advance is ground in?
Thanks
Old 09-25-2005, 05:56 PM
Gotcha's Avatar
forgot this:
http://cranecams.com/index.php?show=...65&lvl=2&prt=5
Old 09-25-2005, 06:33 PM
vettenuts's Avatar
I just installed that very cam in my car (Boss II). I used the Crane springs. I know the Comp 918's are a favorite here, but I have to tell you that my setup is as quiet at stock. I have absolutely no sewing machine noise, and I believe the springs have a lot to do with it (my opinion). I really need a tune though, I took it out for a 100 miles drive today and the tailpipes are full of soot.
Old 09-25-2005, 06:43 PM
smask04C5's Avatar
Excellent cam choice, but get the 144832 dual spring kit. As vettenuts said, they appear to be a quiet combination
Old 09-25-2005, 07:25 PM
superchannelkev's Avatar
get dual's.. i just had to help a friend today where one of his vlavesprings broke and he was able to drive ~20 miles home one a broken outer valve spring, wouldnt have been to pretty with a dropped valve
Old 09-25-2005, 07:32 PM
mrr23's Avatar
get the duals. it's what's designed for that cam. i'll say that for any cam. use whatever springs they recommend.
Old 09-26-2005, 04:55 AM
XTrooper's Avatar
Need them? I don't know, but I'll give you my experience. When I first installed the Crane 1.80 Quick-Lift roller rockers, I was using a brand-new set of PRC dual valve springs. As it turned out, they didn't like each other and I got a bad dip in power at the top-end resulting from harmonics/valve float. When I switched to the Crane duals, the dip went away and I picked up another 10 rwhp.
