How much can stock crank and block take??
Old 10-01-2005, 10:31 AM
GFORCE1320's Avatar
Default How much can stock crank and block take??
Can someone tell me how much hp a stock LS1 crank can take as well as the stock alum block, I'm looking at either TT or nitrous. And do most people get the block o-ringed?
I'm getting ready to build a new LS1 and if I can use the stock crank and make 600-800 on it then I won't waste money on high $ crank.
Here is what it is going in, and yes that is a Mustang.
Attached Thumbnails How much can stock crank and block take??-98-mustang-front.jpg
Old 10-01-2005, 11:44 AM
BlueSix's Avatar
If 600-800 is what you are shooting for then the stock crank will be fine.
Old 10-01-2005, 11:48 AM
GFORCE1320's Avatar
I've heard that a stock crank will live in a 1,000 hp or rather an 8 to 9 sec. car. That sure sounds like a hellofa lot of stress for a stock crank. But then again the LS1 has a real good set of mains and caps to support it.
Old 10-01-2005, 12:50 PM
wanklin's Avatar
planning on an LS1 stang?
Old 10-01-2005, 01:21 PM
black_z's Avatar
Youll be fine with the stock block and crank, make sure to get a good tune.
Old 10-01-2005, 01:26 PM
PREDATOR-Z's Avatar
Once you have the block mock assembled and all clearances checked
( blueprinted), then you criogenicaly treat the crank. You'll be able to do 1000 hps all day.
Another way to strengthen the crank is to nitrate treat it.
Old 10-01-2005, 03:09 PM
GFORCE1320's Avatar
What about O-ringing the block, probably a good idea huh?
Old 10-01-2005, 03:10 PM
GFORCE1320's Avatar
Has anyone ever chunked the stock crank?
Old 10-01-2005, 05:30 PM
BlueSix's Avatar
If you asking if a stock crank has ever failed because of too much power then the answer is No.
Old 10-02-2005, 12:14 PM
GFORCE1320's Avatar
Judging from the responce or lack of, I would say that Bluesix is right and that the stock crank is a good choice and not to spend your money on the high dollar cranks.
If anyone has a different opinion, let me know as I'm about to go part shoppin
Old 10-02-2005, 01:31 PM
PREDATOR-Z's Avatar
I gave you mine. At least nitrate it or at best cryo it.
Old 10-02-2005, 01:48 PM
TS6
TS6's Avatar
I think he is.
Signed, your good friend Mr. Obvious.
Old 10-02-2005, 02:12 PM
DavidNJ's Avatar
A lot depends on use. A street strip car which is only at peak torque for a few minutes/year on the dyno and strip, these parts can last a long time.
On a road race, oval, or off-road racing car, where the engine run for hours/month at peak torque...the stock crank may fail. Even at moderate power levels. To avoid that you would need to have it x-rayed to insure it is ok. Machining would create radiuses on the journals to reduce stress level. Then you would probably cryo-treat it (to enhance the internal metal structure) and use either an induction harding (like Callies) or a surface hardening (like nitriding) to reduce the chance of crack propagation.
An aftermarket race crank would use material with higher yield stresses and typically have the radiuses, etc to minimize stress levels.
Old 10-02-2005, 03:06 PM
GFORCE1320's Avatar
Originally Posted by TS6
I think he is.
Yes, a stang is what I'm planning but if it's not fast when I'm done i'll never hear the end of it form either side !
I'll start posting my progress once I start coming up with interesting stuff.
Old 10-02-2005, 08:59 PM
wanklin's Avatar
lol. And I thought I got flack for an LS6 RX-7. I can only imagine that hate mail that you are going to get. Rock on.
Old 10-02-2005, 09:02 PM
wanklin's Avatar
There seems to be speculation as to the true effectiveness of cryo treatment. Some say that it can actually make the metal that you are treating too brittle. Not sure if that substantive or hearsay.
Old 10-02-2005, 09:23 PM
DavidNJ's Avatar
It is my understanding that after quenching of steels some austenite is retained in the martensite. And they the cryo treatment completes the transformation. While high cycle fatigue improvement of parts such as cranks and rods may be speculative, brake rotors show a clear and significant improvement.
Apparently, the carbides (carbon clusters causing brittleness) are smaller and more evenly distributed after the cryo treatment.
I have not seen any explanation for cryo treatment for non-ferric parts, although one might exist.
And now we are close to the limit of my metallurgy knowledge.
Old 10-02-2005, 10:02 PM
wanklin's Avatar
I'm impressed ;o)
I'm sure there is some R&D data out there on this somewhere.
Old 10-03-2005, 11:23 AM
GFORCE1320's Avatar
TTT
How about a few other opinions.
Old 10-03-2005, 01:50 PM
PREDATOR-Z's Avatar
I've used cryo treated cranks , piston rings, cylinder sleeves etc.. in 900 > 1200 HP Toyota twin Turbo six and skyline R32's.
it does work.
The only thing I had to change often were my clutches and trannies.
