Help!!! I swap intakes and get 0 oil pressure!!
I fire up the car and I get a check guages light (the red one) and no oil pressure, all I did was swap the intakes. I kept the same injectors and everthing. Please help!!
Originally Posted by ATLHwyRacer
is it safe to drive my car to the dealership with this sender broken? What is its purpose
I think I accidently unplugged it but i almost swear i plugged it back in, but can someone tell me if its ok to drive with it unplugged and/or broke? till I can plug it back in or buy a new one and fix it
Look at it this way it worked fine before you replaced the manifold, oil prs that is. I would at least start the engine and make sure you did not brake it off to the point you have a oil leak. And if not and you need to drive it, to get a new part ect go for it. I would not plan on driving it along time with no way to watch the oil prs.
I took a mirror to the back of my intake and looks like you guys were correct. Something is bent over sideways the bottom part is a copper like color looks like what used to stick up and down is now bent over sideways and broke in 2.
Show me a picture of this please so I know what to change
Now you will need a special socket from autozone. It is like $5 and it says it's an oil sending unit socket.
I broke my sender just like you, installing an intake manifold. It sticks up at the rear of the valley, and nestles in a hollow at the back of the manifold. If you don't get everything centered just right you can snap the sender off its base. When this happens, you (obviously) lose oil pressure reading but there is no oil leak, no SES light and oil pressure is fine.
The part is $50 from a local chevy dealer, $25 online.
Not to hijack the thread, but...
I have a similar situation, changed the intake and my pressure gauge is pegged! over 100 PSI... Anyone ever seen this before? I was thinking a grounded out wire somewhere?
