Patriot Gold Dual spring pressures?
Does anyone Know what the spring pressure are for Patriot Gold Duals at the seat and at .600?
Thanks
Thanks
Seat Pressure @ Installed Height
Open Pressure and Height
Coil Bind
Maximum Net Lift w/.060" Clearance
Average Spring Rate (lbs./in.)
135@1.800
350@1.150
1.090
.650"
365
Coil Bind
135@1.800
350@1.150
1.090
.650"
365
I set up a spread sheet to look at the problem I am currently having with my Cranes, I think the Comp 921's are the only thing that will get you the numbers you are looking for. I have it figured for 1.76 installed height and .583 lift, but with those numbers you would get 140 and 421 respectively.
