tools to mildly touch up heads
Old 10-22-2005, 06:12 PM
ninobrn99's Avatar
Question tools to mildly touch up heads
Can I use a dremel or something to touch up the intake and exhaust ports on my heads?? i just got my ls6 heads in and wanna smooth out the ports.
Nino
Old 10-22-2005, 07:10 PM
CBX
CBX's Avatar
ttt
Old 10-22-2005, 07:36 PM
krexken's Avatar
You'll be there all year with the average little dremel. If you don't have an air compressor to power a normal die grinder, Dremel does make a 1/4" drive die grinder with a remote motor though. Most stores like Lowes don't stock it but it's probably available. You'll want a 4-6" long mandrel for some sand rolls to really polish that thing up. Lotsa machine tooling supply stores carry this stuff and some welding supply shops.
Old 10-22-2005, 07:40 PM
CBX
CBX's Avatar
How much material can you safely remove? Can you open it up right to the size of the header flange opening?
Old 10-24-2005, 01:22 PM
777's Avatar
Don't open the exhaust ports to the header flange, it messes up the flow charecteristics of the exhaust gas.
