Any special prep work needed when installing 3.9" crank?
Old 11-04-2005, 04:21 PM
FastKat's Avatar
Default Any special prep work needed when installing 3.9" crank?
I know when you go up to the 4" stroke you need to shim your windage tray, clearance your block (for the reluctor ring I think) and also some other things. Do you still have to do the same extra prep work with a 3.9" crank?
Thanks a lot -Dave
Old 11-05-2005, 01:02 PM
FastKat's Avatar
ttt - anyone?
Old 11-05-2005, 03:25 PM
goober35's Avatar
NO but you need to take the rotating asemble to the mechine shop and have it balenced.
Sorry for the spelling.
Old 11-05-2005, 04:22 PM
FastKat's Avatar
Awesome, what components did you go with?
Old 11-05-2005, 05:01 PM
goober35's Avatar
Everthing in the bottom end exsept for the bearings. I had the mechine shop provide those.
Pistons, Rods, Block and main caps.
