PTV clearance question.
Old 12-01-2005, 04:27 AM
HartAttack's Avatar
Default PTV clearance question.
I have a G5x2 (232/240 .598/.610 112 Lsa +2) and was considering some 5.3 truck heads that are milled .007 for compression on bottle. But would the cam fit without flycutting is the question??
Thanks
-Chris
Old 12-01-2005, 04:29 AM
PREDATOR-Z's Avatar
I would say NO.
.007 is not a mill it is more like a decking. But I'm assuming those are ported 5.3's with bigger valves than stock.
Old 12-01-2005, 12:44 PM
John02SS's Avatar
Naw, Chris it won't fit. That cam is very close on Stock heads with stock valves. I'd flycut and be done with it. That is the situation I was in and I said hell with it and bought a short block.
John
Old 12-02-2005, 04:22 AM
HartAttack's Avatar
John
I'm not a baller like you brotha
Thats fine, i will just go cam only...You still got some 241 heads at your place?
