Show us Pic of your Ported FAST Intake
Old 12-01-2005, 11:25 AM
SlickVert's Avatar
Default Show us Pic of your Ported FAST Intake
If you have a ported Fast intake show us your pic and any recommendation that you may have.
Old 12-01-2005, 12:16 PM
ROCNDAV's Avatar
I would love to see this too.
Old 12-01-2005, 12:24 PM
7 Second Club
Phil99vette's Avatar
I just ported one and if you search you'll find pics.
1) Mock up engine outside of car
2) Disassemble FAST
3) WIth the bottom 2 pieces of the fast mounted on the engine bolted down use a carbide burr to radius the entry so it meets the external dimensions of the intake port
4) Once all 8 ports are "port matched" roughly 1/4" in than remove the intake
5) With a 200-400 grit sanding roll 2" long or so smooth the "port matched" section to the runner. Use the temperature of the plastic to tell if its getting thin.
Once everything is done you will see its a smooth transition from the runner into the port.
Phil
Old 12-01-2005, 01:43 PM
ROCNDAV's Avatar
Phil, how far back did you go? You ported the runner the whole way, correct?
Old 12-01-2005, 05:50 PM
7 Second Club
Yep, I went back up about 3 - 4" or so. Looking at an unported vs ported is a big difference but my runners are thin in some places.
Phil
Old 12-01-2005, 06:45 PM
Tony99SS's Avatar
Phil, et al, maybe you can answer a question for me: I am presently porting my FAST 90 as well, The top piece of the three easily seperated from the two black ones, after removing the bolts. The middle piece is IN THERE, though! I removed the screws and pulled as hard as I dared everywhere i could grab hold, and it never budged. I am afraid to pry them apart since it is plastic...
Any tips? Should I even bother with seperating the lower pieces?
TIA
Tony
Old 12-01-2005, 06:53 PM
ROCNDAV's Avatar
IIRC, there are more screws aren't there? mine seperated pretty easily IIRC.
D
Old 12-01-2005, 08:43 PM
7 Second Club
Just remove the lid.
Phil
Old 12-02-2005, 12:20 AM
Jimmy P's Avatar
Has anyone been porting the FAST to match to the ETP heads like Tony Mamo is porting them to mate up to the AFR's? I wouldn't trust myself to port an $850 intake.
Old 12-02-2005, 08:05 AM
7 Second Club
I don't know how tony is porting them but I just did a Fast for a ETP H & C motor.
Phil
Old 12-02-2005, 08:14 AM
SlickVert's Avatar
Phil
Did you open up the top of the intake runner around the injector bose?
Bob
Old 12-02-2005, 08:48 AM
7 Second Club
I radiused the top.
Phil
Old 12-02-2005, 01:14 PM
Brandon Boomhauer's Avatar
any pics phil? come on now, you are the high res photo posting king around here.
Old 12-02-2005, 02:18 PM
7 Second Club
They are posted in another thread....
Old 12-02-2005, 02:21 PM
7 Second Club
Using search I found....
https://ls1tech.com/forums/generation-iii-external-engine/408637-ported-unported-fast-pics.html
Old 12-02-2005, 02:48 PM
thanks phil.
did you ever go back and radius the upper section?
Old 12-02-2005, 03:37 PM
7 Second Club
Yes, radiused the top piece. I am going to bolt it together and throw some JB weld on the one side where its thin and sand it with a fine grit paper.
Phil
